hello again,
ok got a new fuel pump today to replace my broken one. i now have a problem, my old pump was a 800 type (there a three mechanical types: the 700, 800 and AZX) ibought a AZX type. can i use the AZX type insted of an 800. the rubber block thingy is the same. and the mount holes arfe the same??
so can i??
cheer.
Fuel Pumps, Oh bugger.....again
Big_Adam
, Dec 30 2005 01:28 PM
6 replies to this topic
Posted 30 December 2005 - 01:28 PM
Posted 30 December 2005 - 02:40 PM
anyone?? ah sods. i think i might just go with the try it and see method.
Posted 30 December 2005 - 02:42 PM
if anything it sounds like a newer version and therefore could well be an upgrade.
Have you had a look in HBOL
Posted 30 December 2005 - 02:45 PM
i think it is. screw it i'm going to do it. i'll tell you if it exsplodes.
edit
AH, found ot it is the same pump, just the new one has a HUGH flange on it were it's screwed together.
fitted it almost. my engine ate one of the spanners so now i have to wait till tommorow.
edit......again....
dose anyone have a clue were my spanner could have gone. i was using it on the right hand of fuel pump (from the front) and i dropped it then....gone. it's not under the car i can't find the fugging thing
edit
edit......again....
Posted 30 December 2005 - 06:48 PM
Spanner's probably sat sniggering on the subframe.
Posted 30 December 2005 - 06:52 PM
it will be fine as long as u have the plastic spacer plate
dave
dave
Posted 30 December 2005 - 09:49 PM
yeah, got the plastic thing,it will be fine as long as u have the plastic spacer plate
vasi, you probly right, :grin:
