Shock Absorbers
Posted 31 December 2005 - 04:42 PM
I'm looking to spend a max of £50-60 for a complete set (front and back) of shocks but don't really know which would be the best kind to improve the smoothness of the ride and hopefully the handling a bit too.
Does anyone know any good brands and types that would be worth buying?
Thanks very much for your help,
Daniel
EDIT: actually while I'm asking, I've noticed that when I try to use the heater to stop the front windscreen from steaming up or just to generally heat the car there is a horrible squeaking noise which doesn't stop. Any ideas?
Posted 31 December 2005 - 05:07 PM
Posted 31 December 2005 - 05:08 PM
Reduced bounce over minior bumps and work well for general daily use
£18 for a full set in minisports sale
BUT
For you buget
u can get full sets of Spax £40(max), gaz £36, koni £44 and bilstern £49
so realy its take your pick
minisport
<karl>
mine squeaks and rattles could be down to the motor?
Posted 31 December 2005 - 05:14 PM
Are they easy enough to fit?
Posted 31 December 2005 - 05:35 PM
but theres a bit of false advertising going on in the new January 2006 mini magazine,
That would't be the first time by minisport :erm:
The Fronts are the easyest to fit
Jack up car and remove wheel
Remove the two bolts and remove damper
Re-fit new damper in reverse order
what you might find is that the spacer from the old damper has rusted on
easly removed with a pair of mole grips and wd40
Posted 31 December 2005 - 05:58 PM
Driver’s side
Before you jack up vehicle remove the nut from the top of the damper in side the boot
Jack up and remove wheel
Remove nut and sleeve (same prob as front) on radius arm
Re-fit new in reverse order
full tightern the top nut/nuts when vehcle is on floor
Passenger side
To get to the top of the damper you fist have to move the fuel tank
Remove tank strap bolt
Move spare wheel over on to other side of boot
Remove filler cap
Manoeuvre the tank to where the spare should be, just enough to get to the damper and be careful of stretching fuel pipes etc.
support with spare wheel and replace filler cap
And refit the tank in reverse order
Posted 31 December 2005 - 06:46 PM
dave
Posted 31 December 2005 - 06:54 PM
Agreed, ive have very good experiances with these, they dont go rusty either. Unlike my GAZ adjustablesfit the kyb gaz adjust these are very good
dave
Posted 31 December 2005 - 11:41 PM
With shocks you generally get what you pay for. I paid a bit more than your budget to get the KYBs (about $200 from Mini Spares with shipping charges). Stock/standard shocks would have been a little less and should fall in your budget.
Posted 01 January 2006 - 03:39 PM
Posted 01 January 2006 - 05:21 PM
Or the KYB Gas Adjust shocks (KYB) which would cost £93.44 for a set.
They both have pretty much the same specs, 25% uprated for the Gmax and 30% uprated for the KYB. Would it be worth spending the extra £40 and getting the KYB or are the two pretty similar anyway and so better to save the money and opt for the Gmax?
Thanks, Daniel
