[attachment=108047:IMGP1703.JPG]
Upon an investigation with a problem with my clutch, following a recent installation by an 'A series specialist' I have found they were good enough to only put top half of the 5 bolts and not to put back the 3 most awkward bolts at the bottom of the clutch/flywheel cover (near the engine mount). When I sourced 3 more bolts and fitted them, I found my clutch seemed to go too far and would catch.
It got me thinking what could be the problem and the only thing I could think of was flex in the cover (the WOK) when the bottom 3 bolts weren't fitted, when I dis-engaged the clutch.
I got the misses to sit in the car to engage and disengage the clutch .............I was surprised how much flex there was! About a 2mm gap appeared!
The moral of the story is check your bolts at the bottom of the clutch housing cover (oh and make sure an 'A series specialist' is a proper 'A series specialist' when you use them)
Any comments appreciated. Cheers.
Edited by HUBBA.HUBBA, 17 February 2011 - 09:19 PM.
