The photos show the bolts Hubba.Hubba sourced and fitted later, they aren't tightened because he wanted to see any movement.
Yep
Posted 21 February 2011 - 07:45 PM
Posted 21 February 2011 - 07:49 PM
Actually looks like they haven't even tightened them up properly to me, but I do think 3 would be pushing it. If all the bolts where tight, i'd expect the wok to bend & crack.
Posted 21 February 2011 - 07:51 PM
Sounds like you are lucky to be still with us.
Posted 21 February 2011 - 07:57 PM
I think cooperrodeo was replying to the chap who had the flywheel bolt missing. Still not sure what happens if the flywheel comes off whilst rotating, does it fly through the car like a circular saw?Sounds like you are lucky to be still with us.
lol over reaction much? surely worst thing that could ever happen is your unable to disengage the clutch and your stranded for a couple of hours until AA reach you...unless you dont have AA and you starve to death, or you step out the car after stopping because you cant engage a gear and your mullered by a passing bus, or you are pecked to death by vultures who for some reason have made there way to the UK....holy cow ur lucky to be alive![]()
Posted 21 February 2011 - 08:02 PM
Posted 21 February 2011 - 08:05 PM
Posted 21 February 2011 - 08:31 PM
Edited by rick.spi, 21 February 2011 - 08:36 PM.
Posted 22 February 2011 - 09:31 PM
[attachment=108046:IMGP1702.JPG]
[attachment=108047:IMGP1703.JPG]
Upon an investigation with a problem with my clutch, following a recent installation by an 'A series specialist' I have found they were good enough to only put top half of the 5 bolts and not to put back the 3 most awkward bolts at the bottom of the clutch/flywheel cover (near the engine mount). When I sourced 3 more bolts and fitted them, I found my clutch seemed to go too far and would catch.
It got me thinking what could be the problem and the only thing I could think of was flex in the cover (the WOK) when the bottom 3 bolts weren't fitted, when I dis-engaged the clutch.
I got the misses to sit in the car to engage and disengage the clutch .............I was surprised how much flex there was! About a 2mm gap appeared!
The moral of the story is check your bolts at the bottom of the clutch housing cover (oh and make sure an 'A series specialist' is a proper 'A series specialist' when you use them)
Any comments appreciated. Cheers.
Posted 22 February 2011 - 09:55 PM
Edited by valve bounce, 22 February 2011 - 09:55 PM.
