turbo engine
Posted 22 April 2004 - 10:14 PM
Posted 22 April 2004 - 10:51 PM
I have seen one fitted with a Metro rad, but that had the lower valance cut away and you could see the bottom 4 inchs of the rad.
Why would you want to change the rad just for the sake of an oil cooler?
Siggy
PS can't help with the turbo box, but I will mail a guy who has an old GT of mine that was fittted with one.
Posted 23 April 2004 - 07:44 AM
Posted 23 April 2004 - 12:36 PM
You can install a front mounted radiator with a little work. All Minis 96 onwards had a small front mounted rad. These are an excellent bit of kit.
Or with a bit more work you can install the Metro one, i used to have one of these on mine.
I had a Renault 5 intercooler mounted where the side radiator usually is and the Metro rad up front. I have now gone back to the side mounted radiator and i have a big alloy intercooler across the front.
It doesn't cost a lot to install an intercooler i got this Renault one from a scrap yard for £5 & hoses can be used from other cars to connect it. Get hunting ! :grin:
This is how it used to be.........
Posted 23 April 2004 - 12:41 PM
New install...
Posted 23 April 2004 - 09:25 PM
Phil. :grin:
Posted 24 April 2004 - 05:05 PM
Posted 25 April 2004 - 08:57 PM
Posted 27 April 2004 - 01:36 PM
I run a Minispares super 2 core radiator, with a Metro Turbo electric fan mounted under the inner wing for when it's in traffic.
A front mounted radiator will always be more effective as it's in the air stream, but the same goes for the intercooler.
I would mount the intercooler up front, use a side radiator & if you have any overheating trouble then add an extra small radiator or heater matrix between the cylinder head and the heater take off pipe.
Hope this helps.
Phil.
Posted 27 April 2004 - 06:37 PM
Posted 29 April 2004 - 05:08 PM
Yeah water spray will work, i wouldn't pay for one of those kits though it's simple enough to rig something up yourself. I'm working on an idea for one at the mo.
The Metro vented setup is very heavy, i use solid 8.4" drilled and grooved discs EBC green pads and Minispares alloy 4 pots. No probs with stopping, and pretty light.
Phil. :grin:
Posted 29 April 2004 - 07:34 PM
Posted 29 April 2004 - 10:27 PM
If you've got your engine out you can grind some of the block away where the water pump mounts.This will help waterflow a little, Check Vizards book for info.
Also i would advise installing an electric fan under the inner wing for traffic jams.
Phil. :grin:
Posted 02 May 2004 - 09:31 PM
