Best Way To Remove Roll Pin From Gear Linkage?
26 replies to this topic
#1 minidave1991-89
minidave1991-89
  • 406 posts
  • Local Club: Charnwood Minis
Posted 03 March 2011 - 10:06 PM
After finally removing the driveshafts today and stripping the engine bay down i've hit another problem...
The roll pin joining the gear linkage up to the gearbox isnt budging :)
The pin itself is at a very bad angle so i cannot get the correct side to punch it out, but i was wondering if you could hit it the other way out?
Is there any other way of getting this pin out?
Thanks for your support :thumbsup:
#2 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 03 March 2011 - 10:10 PM
Select reverse and you'll be able to punch it through.
#3 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 03 March 2011 - 10:46 PM
I usually have the car in neutral and one of the roll pins is at a better angle/position to the other and should come out after a good hammering. I think when looking at the front of the car you need to knock it towards the 11 o clock position. Never really tried it in any other gear so that could work as HUBBA.HUBBA suggests.
#4 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 04 March 2011 - 01:25 AM
ask chuck norris to punch it through :)
#5 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 04 March 2011 - 01:26 AM
opps double post
Edited by olds_kool_lews, 04 March 2011 - 01:26 AM.
#6 Guest_Zenob1_*
Guest_Zenob1_*
  • Guests
Posted 04 March 2011 - 05:42 AM
Or if you are (un)lucky it'll drop out when you're doin' 60 and trying to change down a gear approaching traffic lights :)
#7 Wil_h
Wil_h
  • 3,244 posts
Posted 04 March 2011 - 08:09 AM
One of these make the job so much easier. I always put it in reverse.
#8 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 04 March 2011 - 08:12 AM
Or do it my way
BRAKE IT OFF :)
my pin had rusted right into the joint so we just lifted the shell and when we did the arm snaped so the pins been sat in oil for 6 months + now
hopefully it go back in :thumbsup:
#9 SolarB
SolarB
  • 1,385 posts
Posted 04 March 2011 - 08:24 AM
I used mine last night, best thing I've ever bought at a show.
#10 minidave1991-89
minidave1991-89
  • 406 posts
Posted 04 March 2011 - 01:18 PM
Or do it my way
BRAKE IT OFF ;)
hopefully it go back in :dontgetit:
I did have a hack at it yesterday and, funnily enough my mate (who's nickname is chuck norris) had a go aswell.
Chuck Norris has been defeated by a roll pin!!
#11 minidave1991-89
minidave1991-89
  • 406 posts
Posted 04 March 2011 - 01:19 PM
Just bought one of those roll pin removers off mini spares, thanks for recommending it ;)
Hopefully here tomorrow so i can finally get the engine out!
#12 LESTA MINI
LESTA MINI
  • 492 posts
  • Local Club: 4th Gear Mini Club
Posted 04 March 2011 - 04:34 PM
ive got one of those mini spare pin punch, i dont really have a gear when doing it, its which ever one works out easiest on that day, i just keep hitting until it goes, and when i replace it i put a cable tie through it oo ensure it doesnt come out while driving.
#13 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 04 March 2011 - 08:28 PM
well me and rob are better than chuck norris then ;]
#14 jfbento
jfbento
    Just On Tickover
  • 6 posts
  • Local Club: Clube Mini Portugal
Posted 11 March 2011 - 04:04 PM
The thing whit the gear being in reverse is that the shaft is more inside thus more suported by gearbox housing. I've read this somewhere before.
I've always done this in reverse gear with an old 5mm dril bit and some carefull and patience. But take the Wil_h advice and buy that tool.
#15 Minimonet
Minimonet
  • 16 posts
Posted 03 June 2018 - 03:12 PM
Just reading this old post! I’m currently removing the pin, my God it’s impossible. I’ve tried everything!!! Sireousoy considering cutting the rod. I need to get the engine out and it’s taking me ages to do the job
Edited by Minimonet, 03 June 2018 - 03:14 PM.
