Best Way To Remove Roll Pin From Gear Linkage?
#16
Posted 03 June 2018 - 03:23 PM
#17
Posted 03 June 2018 - 04:32 PM
#18
Posted 03 June 2018 - 06:29 PM
If the front one is stuck that bad, take out the other pin.
Bashing away at it will only distort the bore in the gearbox and then no matter what, you can be guaranteed it will always leak oil.
#19
Posted 03 June 2018 - 06:55 PM
i used a punch and a lot of moving the gear stick to find the right angle, if i remember one of the gears pulls it out alot and rotates it
#20
Posted 03 June 2018 - 06:56 PM
Yeah. I use single, measured blows. Reposition your parallel punch each time.
#21
Posted 03 June 2018 - 08:59 PM
I am going to cut the rod with an angle grinder. I have tried to drill it and the bit broke inside the pin. Had enough. Beast time.
Having said that, I can't find the gear change rod to replace in minispares. Can it be purchase on its own or do i need to buy a new gear box (hope not)
Edited by Minimonet, 03 June 2018 - 09:11 PM.
#22
Posted 03 June 2018 - 09:15 PM
Of course you may struggle for room and lack of hands...... I'm just thinking out loud really.
#23
Posted 03 June 2018 - 09:26 PM
It might be feasible to cobble together some sort of press. G Clamp, little socket, and a nail.
Why did i not think of that! that's a good idea, a G clamp, i'll give it a try. thanks for thinking out loud
#24
Posted 03 June 2018 - 09:46 PM
Both the standard ones and these upgraded ones are available:
http://www.minispare...16.aspx|Back to
#25
Posted 03 June 2018 - 10:37 PM
I've used Wiggy's method in the past successfully but found it may take a bit of time getting the socket in the right place without it flying off. I've since modified a G-Clamp by cutting a slot in the fixed end so the roll pin passes through as the clamp, with a suitably sized pin, is tightened.
Which reminds me, I have to get it back off my mate.
Good luck.
#26
Posted 03 June 2018 - 10:59 PM
Good luck.
I like the sound of that!
#27
Posted 04 June 2018 - 06:06 AM
Dunno if they are still available, but someone was offering a 'pin press' for removing these pins in situ on a Mini.
