Anyone know what the thread on the single tower bolts is?
I'm going to need 4 "normal" set screws to go into the subframe towers so I thought I'd ask here before trying to count threads per inch and measuring the diameter as that can be a bit hit and miss and you always seem to end up with results smack between two listed threads. With smaller stuff it's just easier to buy one of each of the possibles and see which fits but I suspect these are going to be pricey and possibly special order so would rather get the right ones first time.
Iain
Tower Bolt Thread Size?
ibrooks
, Mar 04 2011 11:27 AM
5 replies to this topic
Posted 04 March 2011 - 11:27 AM
Posted 04 March 2011 - 12:41 PM
That's a bit confusing, there are only 2 bolts on the post '76 frame, and they are shouldered and shanked to tighten on the frame while while locating and compressing the rubber mounts correctly: so unique.
The pre '76 frame uses four 5/16unf bolts, though again the original will be better http://www.minispare...=...6759&title=
Posted 04 March 2011 - 10:20 PM
It's the big post '76 bolts I need to know the thread of. I need normal bolts to replace those unique ones with the long shank. My car uses two front subframes so I need 4.
Iain
Iain
Posted 05 March 2011 - 02:04 AM
Aah fairy muff, I'd be highly surprised if they're not UNF - cones are M14 so they must be bigger than that. 5/8 maybe - that's the same as a manifold servo connection or the temperature sender on the cylinder head.
Posted 05 March 2011 - 06:36 PM
Curiosity got the better of me - 3/4unf
Posted 05 March 2011 - 09:10 PM
Thanks dude - I'll have a word with the nice man in the bolt shop.
Iain
Iain
