Coolant Colour
Posted 04 March 2011 - 07:29 PM
i went to halfords today to buy some replacment coolant (ready mixed) and they asked me if i needed blue or pink but i was'nt sure
i went for the pink but as i disconected the heater matrix both blue and orangey fluids come out which coolant should i use blue or pink
thanks.
Posted 04 March 2011 - 07:52 PM
but now im stuck dont know what to do next. HELP
thanks
Posted 04 March 2011 - 07:59 PM
At the back of th heater case there is a threaded rod running from each side. It is hooked into a plate on the bulkhead and clamped up with nuts, you just need to loosen the nut at one side a bit and lift it out of the hooks.
Posted 04 March 2011 - 08:11 PM
well the pink coolant iv boght says sutibal for cars made 1998 on but mines 1996
Edited by joel93, 04 March 2011 - 08:12 PM.
Posted 04 March 2011 - 08:31 PM
Posted 04 March 2011 - 08:33 PM
if you use the wrong coolant it can clog up the water pump, heater, and other cooling componts
Haynes manuel or Auto Data to find out
Posted 04 March 2011 - 08:34 PM
Posted 04 March 2011 - 08:43 PM
Please type properly on our forum. TXT typing isn't permitted.
Posted 04 March 2011 - 08:44 PM
thanks
Posted 04 March 2011 - 08:47 PM
Posted 04 March 2011 - 08:56 PM
don't forget your engine is basically the same from 1959 when it was first designed so although your car is a 1996 the engine design and components are much older
i do believe the a series engine made its apperence in 1951
Posted 04 March 2011 - 10:04 PM
Dan Is right!
Posted 04 March 2011 - 10:19 PM
Read the instructions carefully IIRC theres 3 or 4 types
Edited by wolfie, 04 March 2011 - 10:22 PM.
Posted 04 March 2011 - 10:22 PM
And I'm old and struggle to understand it
Stick to blue, especially if it's had blue in before, apparently they don't mix
