Coolant Colour
22 replies to this topic
#16 the_r_sole
the_r_sole
  • 831 posts
Posted 05 March 2011 - 09:16 AM
can anyone say what the haynes manual says please?? i've got a 96' spi and i'm more than 100 miles from my manual!! was going to go to halford and waste some money today!
#17 Ethel
  • 26,137 posts
Posted 05 March 2011 - 02:08 PM
It won't say much as there were only 2 choices for most of the Mini's life - both usable.
"If this is not available, use an ethylene glycol based
anti-freeze, containing no methanol with
non-phosphate corrosion inhibitors suitable for use
in mixed metal engines", so sayeth Rover.
#18 miniman24
miniman24
  • 1,696 posts
Posted 05 March 2011 - 09:52 PM
I just used water from the tap in my coolant system, as does my dads jeep which has done hundreds of thousands of miles with just tap water and antifreeze, no probs. Not damaging the engine am I?
#19 starletman
starletman
  • 249 posts
Posted 05 March 2011 - 10:27 PM
+1.The a series was designed to have water in it.Add anti freeze if your not sure what type to use just add vodka.
#20 M44K TS
M44K TS
  • 3,104 posts
Posted 05 March 2011 - 10:40 PM
If you use water only, you run the risk of rust forming in the water galleries, antifreeze has rust inhibitors in it amongst other things to protect the engine block.
#21 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,091 posts
  • Name: Neil
Posted 05 March 2011 - 11:05 PM
The major problem is the rust building up in the radiator effectively reducing its cooling capabilities leading to over heating. Been there done that. Also it will start to block the water galleries again reducing flow etc. You will need to flush the engine using a good quality flushing compound to remove as much of the build up as possible. If you are lucky you will not have done too much damage.
Engines have anti freeze in them for a reason, by not using it can cause severe problems. Worst case scenario especially with the extremely cold weather we have had recently could be a split block, ruptured radiator etc. Its also acts as coolant during the summer months so again possible overheating can be a problem.
#22 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 05 March 2011 - 11:31 PM
as above in the summer it increasing the waters boiling point so you dont over heat.
#23 miniman24
miniman24
  • 1,696 posts
Posted 06 March 2011 - 10:29 AM
I do use the correct ratio of antifreeze at all times, sorry if that wasn't clear :P
