Primary Oil Seal To Clutch
#16
Posted 07 March 2011 - 10:24 PM
#17
Posted 07 March 2011 - 10:49 PM
The problem I have found is that when you push the clutch housing and seal over the crank there is a tendency for the seal to be pushed inside out
You would know if it wasn't sitting properly like so
Yours looks fine, but as said already, they always look fine!
#18
Posted 12 March 2011 - 07:53 PM
Always lap the flywheel on to the tail, however if your tail is damaged you really need to sort out another crank and flywheel.
Most likely caused by shoddy work
#19
Posted 12 March 2011 - 08:05 PM
#20
Posted 12 March 2011 - 10:46 PM
#21
Posted 12 March 2011 - 11:09 PM
#22
Posted 12 March 2011 - 11:25 PM
Is it me or is the oil seal sticking out quite a bit? They are usually recessed in a lot more?
I can't see you sticking out at all, so it must be the oil seal ....
#23
I really don't think there is anything wrong with your oil seal... and it's certainly not the cause of your clutch problem. Was there a stepped washer present - securing the flywheel to the crank ?? As MRA suggests - you can try lapping the flywheel onto the crank tail - it 'may' be ok. Start with fine valve grinding paste - and finish off with (paint) cutting compound - and clean and degrease both surfaces carefully (use carb cleaner = toluene) - and cross your fingers...........
I've have now fitted the correct non verto stepped washer. The previous one fitted was the small verto type and the lock tab was not even tapped in. It was just acting as a flat washer really. The bolt could have easily just come undone!
#24
Posted 12 March 2011 - 11:28 PM
#25
Posted 12 March 2011 - 11:30 PM
#26
Posted 12 March 2011 - 11:44 PM
No, but it could have done if left.Oh dear - so was the flywheel spinning on the crank tail?
FYI here's a better pick of the old oil seal.
[attachment=109322:IMGP1829.JPG]
#27
Posted 12 March 2011 - 11:52 PM
It transpires this 'specialist' has made a habit of bodging.The world is full of A series specialists, a majority of them should be allowed to own a tool set let alone a use them on someones car. The Governemnt is considering bringiing out a legislation to stop this sort of thing from happening in the future.
#28
Posted 13 March 2011 - 12:09 AM
Compared to the one I have now fitted with the minispares special tool, yes it was sticking out.
#29
Posted 13 March 2011 - 01:03 PM
Edited by Ferretboy221, 13 March 2011 - 01:04 PM.
#30
Posted 31 March 2011 - 07:01 PM
