MED prepared A+ 1380 Block ex 1275 MG Metro. The block has not been used since I got it back from MED.
Specification:
The block has been bored, honed, skimmed, chemically cleaned, fitted with new Cam bearings (and reamed), drilled / tapped for 11 stud head and fitted with a Centre Main Strap.
All work carried out by MED engineering - and I have the original receipt for the work done.
CC = 1380
Bore = 73.5mm
New Cam bearings (have been reamed)
Drilled / tapped for 11 stud head
Fitted with MED Centre Main Strap
Skimmed (to suit 11.5cc dished pistons, with 21cc combustion chambers)
All new Core and Oilway plugs included
Any damaged threads repaired using helicoils (on the transfer housing side - no damaged threads on the head side)
Chemically cleaned
I'm not hiding anything behind shiny layers of paint here, the block is as it is when I collected it and will need a thorough clean before it is rebuilt. It is however in excellent mechanical shape as you would expect of anything that has been worked on by MED.
NO longer needed as have brought a complete engine already done
I am happy for collection in person or you can arrange your own courier from swindon
Thanks for looking; any questions please ask!
£220
Med Prepared 1380 A+ Block (73.5mm Bore) Unused
malcs_miniturbo
, Mar 08 2011 08:03 AM
7 replies to this topic
Posted 08 March 2011 - 08:03 AM
Posted 08 March 2011 - 09:53 AM
pm'd
Posted 08 March 2011 - 06:04 PM
pmd ya back
Posted 08 March 2011 - 06:07 PM
i can wrap this up if you live to far so you can arrange your own courier cheers
Posted 08 March 2011 - 06:10 PM
is this sold?
cheers
cheers
Posted 08 March 2011 - 08:40 PM
Is this sold or not?? )
Posted 08 March 2011 - 09:02 PM
Interested if it's still available
Posted 08 March 2011 - 09:08 PM
sold
