How to......sports pack arches
eddyg
, Jan 04 2006 03:08 PM
8 replies to this topic
Posted 04 January 2006 - 03:08 PM
Has anyone done a how to guide to fitting sports apck wheel arches?? OR know where to get one? Just trying to fill my thirsty cranium with info...
thanks
thanks
Posted 04 January 2006 - 05:02 PM
Never done it mate, too big for my liking. But i am sure that Minispares do a template kit for about a tenner.
I think it was them anyway....anyone??????
Posted 04 January 2006 - 06:29 PM
we never used a template to fit mine and they have come out perfect :tongue:
Posted 04 January 2006 - 06:32 PM
Ive got some coming tommorow. I'm scared of ruibibg them. You can get templates off ebay for about a fiver i think. Lots on there. If you get copy arches i think they just bolt onto special arches...
Posted 04 January 2006 - 07:14 PM
woh woh hold up.
if you go onto minispares website and look on there page about how to fit stuff you can down load the templates for free.
all you have to do is make sure you print them to the correct scale and then stick them together thats what i used and they were fine.
i will put up a link when i find it......................
SORRY THIS NO LONGER EXISTS
Edited by MOWOG, 04 January 2006 - 07:18 PM.
Posted 04 January 2006 - 07:20 PM
ok i was looking in the wrong place its in the downloads section if this link doesnt work you may have to sign up to become a member
sportspack fitting
its at the bottom of the page
sportspack fitting
Posted 04 January 2006 - 08:18 PM
how are the arches actually attched??
so u cut out a bit of the wheel arch then are they riveted on or what? sorry just never seen it done before!
Posted 04 January 2006 - 10:43 PM
right they are bolted on nut and bolt job and you have to cut the front arch away a bit if you have 13s someone will correct me if im wrong im sure lolhow are the arches actually attched??
Posted 04 January 2006 - 11:00 PM
the arches should come with 5 studs which are threaded on them these go through holes you drill in the arch and then nuts are placed on the inside. at the bootom edge near the door you can use a pop rivet or a screw to sercure.
as stated register with mini spares they have free templates.
