Sierra 7" Diff Questions
Posted 19 March 2011 - 04:29 PM
Also, what size rose joints are used for the trailing arms, I already have some but they look slightly larger than z cars? I cant see this being a problem i am just curious as to what i can get away with.
Cheers all, Harry.
Posted 19 March 2011 - 04:55 PM
David
Posted 19 March 2011 - 05:14 PM
The 7" lsd sierra uses 100mm lobro joints and the 7.5" sierra uses 108mm lobro joints neither of them are suitable for mini driveshafts. Unless you use a mini diff you will need to make/get custom driveshafts. Z cars used to use sierra stuff but as it became more and more scarce they have changed to a more modern differential, not sure what it is
David
Cheers David, can i weld them together? The only reason im asking is that welding hardens the steel making it more brittle/prone to cracking. Has anyones ever cracked from welding? I have access to a lathe so i could modify them so they were near perfect. Or would i have to start from scratch using the lathe. Harry.
Posted 19 March 2011 - 05:48 PM
David
Edited by R1mini, 19 March 2011 - 06:03 PM.
Posted 19 March 2011 - 07:14 PM
I'm not a fan of welded driveshafts, but people have used them sucessfully, but then again I've seen a few broken ones, I suppose it's down to how well they are done, if I were to do welded driveshafts I would weld them together first and then slide a piece of cds tube over the welded joint and weld that
David
Not a bad idea actually, im coded so i know they will be welded properly and i think il try what you just said. Ive got to get a load of cds tube anyway for the roll cage and front and rear subframes so a little more wouldnt hurt. Im also going to try and merge the front and rear subframes to the roll cage to create one complete frame. Better handling? Who knows but its worth a go. Thanks.
Posted 20 March 2011 - 11:52 AM
David
i just rung up chris and got zcars diff and arms for mine
