In great condition, removed from a 95 SPI cooper, very low miles. Only used for MOT purposes as a carb set up was run with straight thru exhaust - £25
Collection only due to size
Bottom
Top
SPI Flexi downpipe
I also have the flexi downpipe from manifold to cat section, unfortunatley this was cut and is missing the flange which joins to the cat. However maybe of use to someone where the flexi joint has gone and this could be used to replace with a bit of welding. Apart from missing the flange it is in great condition - £10.
SPI Manifold with Lambda sensor
I also have the manifold for sale with lambda sensor included, this is also in good condition. - £25 + postage which will be £8 by courier
Catalytic Converter
In excellent condition, only used for MOT, honeycomb internals in great condition. - £30 + postage which will be £8 by courier
All of the above came off a functioning but rotten car with only 27K on the clock.
Or take the lot for £75.
PM me if you have any questions or would like more info.
Cheers for looking
Edited by new_van_man, 30 March 2011 - 08:59 AM.
