Which Final Drive ?
Posted 26 March 2011 - 06:02 PM
Im just doing a little research on what final drive to fit.
Ive been on the internet using the speed/rpm calculators and with the wheels/tyres im using ( 175/50/13 ). and a 3.4 FD, 70mph will be at 3000 rpm in 6th gear which i think is roughly what most modern cars are like.
Ive looked on the internet for a 3.4 with no joy.
Is it even possible to get a 3.4 FD for a Honda K20a2 ??? and if so where from ???
The car will be used mainly on the road and i would like it cruise on the motorway at a comfortable rpm.
Any suggestions??
thanks
Chris
Posted 27 March 2011 - 02:51 PM
Richard
Posted 30 March 2011 - 12:37 PM
The 4.0 from CRSX will do you just fine and is a bargain price compared to mine, plus its readily accessible, no minimum batches of machining and all that malarky.
This is another site I found for working out your ratios:
http://ctny.audiworl.../gear_calc.html
Heres a link for the gear ratios of the K20a2 g-box:
http://hondaswap.com...on-specs-29132/
With those wheels and tyres it gives you a theoretcial top speed of 180mph - we both know it'll never do it but still......
82mph @ 4000rpm - not bad....
Edited by cptkirk, 30 March 2011 - 01:51 PM.
Posted 30 March 2011 - 01:29 PM
Richard
Posted 30 March 2011 - 02:46 PM
Chris
Thanks for that Andy ill look into them...
Chris
Posted 30 March 2011 - 02:47 PM
If you go for the Club RSX version you will also need to order a different needle bearing for the countershaft as it's 40mm not 35mm, I've just found this out whilst fitting mine.
Richard
Thanks Richard
Chris
Posted 09 April 2011 - 06:29 AM
Richard
just for reference which one did you order?
was it http://www.clubrsx.com/cr/CLU-4FD.html
and
http://www.clubrsx.c...03-PPT-004.html
cheers
Posted 09 April 2011 - 09:06 PM
Posted 10 April 2011 - 10:27 AM
Yes, that's what I got, although I forgot to order the bearing with the at the time.
did you fit it yourself? i did the diff myself i can now see that i should have got this at the same time ....
Posted 10 April 2011 - 06:26 PM
