The block was refaced on all surfaces 6k miles ago
The center main has been machined for a strap (strap not included) £50
Cast duplex timing gears £5
Rocker Cover £2, Bosch Electronic Coil £3
Lucas Gold Coil (Non Ballast) £5
Unipart Ballast Coil £3
Timing Cover (Duplex Ready) £12
Front Plates (Or back plates if you like) one appears to have been countersunk for duplex £8 each
For the older generation as cassette player £2
Pedal box £5 (no pedals)
Heater (good motor and leak free matrix, no control panel) £ tm donation
MK4 Light RHS £7
MK4 Light Pair £14
Metro Turbo Alternator £5
Boost Gauge £10
Standard trumpets with cones (off a 93 SPI) £7
Drum Backplate £5
Top Arms £12.50
998 water pump pulleys £2 each, Alternators £5 each Fan Spacer £FREE
PDWA Valves £10 each untested
http://www.flickr.co...57624120584014/
Edited by John H, 12 April 2011 - 02:22 PM.
