Exhaust Choice
17 replies to this topic
#16 Cooperman
  • 23,294 posts
Posted 30 March 2011 - 07:40 PM
Ye thats right and thats the size of an rc40, as with sound i believe they are quite nice, but you will get a better sound from a wider exhaust in my opinion. But do you want a to sacrifice power for sound. A question you should pissibly ask is what sort of power difference will it make?
So does increased bore reduce power?
The exhaust internal bore diameter is important. Too small and it restricts the flow of the exhaust gas and too large and the flow speed along the pipe is too low and power is lost. That's a simplification of the physics, but the key thing is that at the revs where the cam/head combination are able to give best power, the speed of the exhaust gas molecules must be correct from the end of the exhaust manifold to the final output from the exhaust pipe. It has been found that for 1275 engines the optimum is 1.75" internal diameter and for the 998 it is 1.625" I.D. If a larger final output pipe is fitted (or even those useless twin pipes), the exhaust gas pressure in that larger pipe will increase and the gas velocity will reduce and that is also bad for power. At revs over about 7500 rpm with a 1275 a 2" int. dia. pipe is fine, but that is for out & out race engines really.
#17 Liam Mini 35
Liam Mini 35
  • 412 posts
  • Local Club: sheffield mini club
Posted 30 March 2011 - 08:07 PM
Here you are liam got some on the pc but cant post them decals been removed as kids started to remove them
http://www.facebook.com/home.php#!/alb...&aid=272197
Looks very nice. Had a quick look at it at MITP. Those alloys are nice what are they? Also is the back riding a little high?
Edited by Liam Mini 35, 30 March 2011 - 08:09 PM.
#18 aspinkney
aspinkney
    Just On Tickover
  • 9 posts
  • Local Club: Durham Mini Club
Posted 31 March 2011 - 07:40 PM
Dunlop D1's with Yokos came with car!!! may be for sale if I can get any Sportspack alloys cheap!!
Rear End was really high sorted problem with a full set of gas shocks and a set of adjustrarides just say get your hands in between the arches now!!!
