Reverse Rims And Coops S Disk Brakes With No Arches
21 replies to this topic
#1 matthew_leech
matthew_leech
  • 428 posts
  • Local Club: Clubless
Posted 30 March 2011 - 09:08 PM
i want to fit cooper s brakes to my mini.
it is a clubman estate with reverse rims with std drums.
i DONT wont arches, but been told many times that it will because the track will be 2" wider.
so hows he doing this? as this is how my mini looks now on drums? (from nov 2010 issue miniworld)
Attached File  Picture0005.jpg   77.51K   174 downloads
is it the 1.5 negative degree camber lower arm?
any feedback much appreciated
Edited by matthew_leech, 30 March 2011 - 09:09 PM.
#2 Spitz
Spitz
  • 1,716 posts
Posted 30 March 2011 - 09:31 PM
Technically that car should have arches anyway.
Are those reverse wheels in the pic or regular 4.5" S wheels?
#3 Cooperman
  • 23,326 posts
Posted 30 March 2011 - 09:35 PM
You can just fit Cooper 'S' standard offset 4.5 x 10 under a non-arched Mini, but reverse rims will definately need arch extensions to remain road legal.
#4 matthew_leech
matthew_leech
  • 428 posts
Posted 30 March 2011 - 09:37 PM
they are "4.5x10-inch dunlop reverse alloys"
Edited by matthew_leech, 30 March 2011 - 09:39 PM.
#5 MiniLuke
MiniLuke
  • 1,205 posts
Posted 30 March 2011 - 09:43 PM
Well they are not alloys, and I would doubt they are reverse ones either if he has 7.5" discs.
#6 Cooperman
  • 23,326 posts
Posted 30 March 2011 - 09:58 PM
I tried a set of those and they won't legally fit under the standard Cooper 'S' body without arch extensions.
#7 matthew_leech
matthew_leech
  • 428 posts
Posted 30 March 2011 - 10:07 PM
just quoting the mag, the topic of these type of steels is so hazy :techsupport:
#8 matthew_leech
matthew_leech
  • 428 posts
Posted 30 March 2011 - 10:13 PM
more research has uncovered that the dunlop reverse rims have an et of 16 making them able to stay slightly further under arches
#9 Cooperman
  • 23,326 posts
Posted 30 March 2011 - 11:13 PM
But they still definately need arch extensions.
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 30 March 2011 - 11:16 PM
You don't want reverse rims for this, you want Cooper S rims. They are not the same thing contrary to popular belief, there is a lot of confusion about this but the Cooper S rims are designed to keep within the bodyline when fitted over S discs. Having said that, it's unlikely you'll want to use original size tyres so you might still have some tread protruding.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 31 March 2011 - 05:57 AM
No matter what you try, Reverse rims on isk brakes will stick out, it's just how much which is the question.... the old trick is to use the 'Delux' body trim round the seam and arch which can be made to look like the wheel is covered... and if you lower the suspension, at the front this will bring the top of the wheel in
This is Reverse Rims on 7.5" disks...
#12 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 31 March 2011 - 06:48 AM
you could get your rims cut down the middle and a inch removed before welding them back together
(a bit like banding but remove metal not adding it)
#13 matthew_leech
matthew_leech
  • 428 posts
Posted 31 March 2011 - 07:01 AM
that looks amazing!
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 31 March 2011 - 07:59 AM
Or buy a set of cooper S rims, as it would be a lot cheaper...
#15 matthew_leech
matthew_leech
  • 428 posts
Posted 31 March 2011 - 09:11 AM
I am aware of the difference in the offset. I just really like the look of the steels with some lip showing :techsupport:
