Small End Bearing
#16
Posted 03 April 2011 - 07:53 AM
The reason you can't hear the knocking so much from cold start is because the oil is still cold and relatively thick and sticky.
#17
Posted 03 April 2011 - 09:07 AM
referring back to a comment earlier, you said you put the original cam back in after finding the sw5 cam to be 'rather worn'.... did you replace the cam followers at the same time ?
Yeah I did
when I rebuilt the engine i replaced
Cam (original)
Cam Followers
Thrust Washers
Big end shells
Crank Bearings
All Bottom and top seals and gaskets
Piston Rings 1275 +20
Tightened up all bolts to the correct tourqage according to manual.
Set rocker gap
Mike
#18
Posted 03 April 2011 - 10:46 AM
I've seen cranks hitting on on the cam lobes, if the cam timing is out you'll bend valves and get knocks
#19
Posted 03 April 2011 - 07:23 PM
when you rebuilt the engine did you turn it over by hand?
Yeah turned it over a few times to make sure all was ok before refitting as I did not want any issues when it was in.... lol
Cant adjust the cam timing as its an MPi
I am looking to get hold of another Crankshaft just now. Scanning forums and Flee bay for an a+ crankshaft
Mike
