Heya, im going to change my original engine (1098cc) for a Metro engine 1275cc (engine code is 12H 996 AA).
but i have some problems/questions:
1/ im looking for new pistons rings, pistons are original (70.6mm) , number in the piston is 20 832 L8. where can i find the new piston rings plz?? size is 1.5mm for the compression rings and 4mm for the oil ring.
2/ same for the cranckshaft (cam 6232) : looking for the new bearings (the bearings now are 3 with a hole and number is: 12G 3467 and A4641 010 )
( 3 without hole and number is: ADU 6443 A6568 010)
3/ "conrod" bearings: number of bearing is now is GS 2123 SA 010 u/s t/b where can i find new ones??? the number in the conrod is 12G4114
4/ how about straight cut dropgears? what are the options (number of teeth)??? can someone give me some advice about that plz???
many thx!!! Fozz.
"new Engine" Im My Clubman Estate
Fozz
, Apr 04 2011 04:42 PM
2 replies to this topic
Posted 04 April 2011 - 04:42 PM
Posted 04 April 2011 - 06:04 PM
about the gearbox: these are number of teeth:
primary gear: 29 teeth
idler gear: 37 teeth
what are the options/combinations for S/C drop gears???
the only reason i want to change from helical to S/C is because i luv the noise. i guess many people here have experience with S/C dropgears... so plz help me )
grtz.
grtz.
Posted 05 April 2011 - 06:24 PM
nobody?????
