Hey guys,
Iv read through most of the posts on this part of the forum and im also looking at doing a bike conversion....
I would like to use the mini Differential but im unsure of the best and cheapest way of doing it, im not going for a £10,000 build this one is going to be on a budget as it will be a track car. I am going to build the subframe myself...
one question I have is would a solid diff work on track with a bike engine? something like this
http://cgi.ebay.co.u...e=STRK:MEWAX:IT
Also where is the best place to buy the bearings and carriers for the differential? what size are the bearings also?
Jim
Diff Choices
Big_jim
, Apr 15 2011 08:05 PM
2 replies to this topic
Posted 15 April 2011 - 08:05 PM
Posted 16 April 2011 - 06:18 AM
alrite i am using the minispares crosspin diff but i had to sleeve one off the sides shafts as i swiched to sealed bearing and used a common size just in case i needed to change not sure what sizes of the ones i used of top of me head i will measure later and post if you want
Posted 16 April 2011 - 10:56 AM
Yes please mate, did you just use a normal bearing carrier then?
Also did you seal your diff and grease/oil it?
Jim
Jim
