Cooper S (aeg 521) rod bolts ARP
cooper S big end +20 vander bearings
maniflow 2" exhaust
Wanted: Maniflow Large Bore Exhaust, Arp Cooper S Rod Bolts
danrock101
, Apr 16 2011 05:56 PM
6 replies to this topic
Posted 16 April 2011 - 05:56 PM
Posted 16 April 2011 - 06:11 PM
i have this if your intrested i think its 1.75 though its good condition just surface rust from where its been sat
looking for £100 manaflow twin
Edited by tieclubbyestate, 16 April 2011 - 06:11 PM.
Posted 16 April 2011 - 06:17 PM
needs to be a large bore, same as this http://www.theminifo...howtopic=179838
Posted 17 April 2011 - 09:48 AM
what is your engine spec?needs to be a large bore, same as this http://www.theminifo...howtopic=179838
Posted 17 April 2011 - 09:57 AM
sorry this is copied and pasted from my excel lol
upgrade
Gearbox
S/C
minispares x pin
S/C drops minispares
3.7 FDD
KAD quickshift
Clutch
Orange diaphram
rally plate
ulralight flywheel
lightend backplate
9 Straps
Uprated bolts
Engine
MED 84mm worked crank Billet crank
Forged omega pistons 73.5mm
Centre main strap
Cooper S rods H beam
Cam
MD296 SP
Belt drive
Standard Pressed steel rockers
Standard cam followers
Head
MED 36/31 Full race 38/31
ARP BOLTS
Exhaust
Maniflow LCB big bore
Maniflow 2”
Carb
Weber 45
38mm chokes
Pipercross air filter
5.5” alloy inlet manifold
Pressure regulator
Facet Red top
Ignition
Megajolt
some of it's changed, only not got the gearbox, crank damper and exhaust now I belive,
upgrade
Gearbox
S/C
minispares x pin
3.7 FDD
KAD quickshift
Clutch
Orange diaphram
rally plate
ulralight flywheel
lightend backplate
9 Straps
Uprated bolts
Engine
Centre main strap
Cam
MD296 SP
Belt drive
Head
ARP BOLTS
Exhaust
Maniflow 2”
Carb
Weber 45
38mm chokes
Pressure regulator
Facet Red top
Ignition
Megajolt
Posted 17 April 2011 - 01:33 PM
i had a very similar spec, put the 2" on, lost loads of torque, put 1.75 on worked a treat, however this will be determined at the rollers. however i am no expert I can only pass on my experiences
Posted 17 April 2011 - 01:41 PM
offer still stands;)
