my first question, mine has a crack between the valves on #1 cylinder i know it can be fixed but should i have it fixed?
second question, i was going to upgrade head later should i just do it now anyway, is there a cylinder head you recomend?
i am aiming for around 6/8 psi on the road and 10/12 psi boost max
your help is much appreciated
Brett
cylinder head
Brett
, Jan 10 2006 12:30 AM
10 replies to this topic
Posted 10 January 2006 - 12:30 AM
Posted 10 January 2006 - 01:33 AM
I'd replace the head with an upgraded 1. Try an Avonbar one like stage 3 or have Mike Barrat at MBE do one for you :oneeye:
Posted 10 January 2006 - 08:20 AM
Two votes for Bin it... when it comes round to it they just aint worth saving..
Posted 10 January 2006 - 08:37 AM
I had a modified head fixed once, but it just cracked again. Maybe in a nat asp motor it would have lasted, but it sees a bit more heat in a Turbo.
Anyway if your heads standard i wouldn't bother getting it fixed, put the money toward a new, nicely modded one.
Phil.
Phil.
Posted 28 January 2006 - 12:03 AM
are morspeed stage 3 turbo heads be any good?
has anyone got one?
cheers
josh
has anyone got one?
cheers
josh
Posted 28 January 2006 - 12:18 AM
ive got a morspeed st2, does the job perfectly. cant grumble at £250 either!
Posted 28 January 2006 - 12:32 AM
so how much more power would you expect to see from a stage 3 than a stage 2 turb head?
would a stage 3 turbo head be ok for everyday use do u think, the rest of the engine is all set up for the job? or would it be a bit on the wild side?
cheers
josh
cheers
josh
Posted 28 January 2006 - 12:56 AM
Bit of a noobie Q,
Can a NA MG metty 1275 head fit onto a trbo and be ok?
Posted 18 February 2006 - 06:43 PM
I'm prob to late but just seen this post.
I have heads welded up and if done well they do last, but it's not a quick or easy job, as they have to heat the head up to cherry red and them weld it, this in turn means you need all new plugs in the head and a skim.
MW
MW
Posted 18 February 2006 - 08:26 PM
http://www.castironw...o.uk/index.html
Though as Miniwilliams said, more so with blocks, it will need re machining, so only worth while if its RARE or EXPENSIVE to replace
I enquired about about the repair of a 1275s block i aquired that was cracked at the main bearing journals. They said they could do it no problem and it would be as good as new, but, and it was a big but, the cost for re machining as well as the crack repair was greater than a 1275s block in good order to start.
Posted 20 February 2006 - 01:38 PM
Bit of a noobie Q,
if boost is kept low or an intercooler is fitted then no real probs here imho
