Engine Steady And Thermostat
Posted 22 April 2011 - 07:59 PM
i also need a thermostat housing for the same engine, the one i need is the split type used on the metros.
thanks nick
Posted 23 April 2011 - 08:06 AM
if you are on about the engine steady over the clutch im shaw i have one and will check about the thermostat housing and get back to youhi there im after a top engine steady for a 1275 cooper carb, must have the rubber bushes with the metal inserts, would also be good to have the bolts but cant have everything lol.
thanks nick
Posted 23 April 2011 - 09:46 AM
thanks nick
we have all the parts you require including new rubbers and gaskets to do the job right, please call us on 01274 945001.
Posted 23 April 2011 - 05:51 PM
