The cars oil pressure according to the gauge is over 100psi at all times, idling, driving etc etc.
Ive also noticed the voltage is 14+
Are these readings normal and how would i go about lowering the oil pressure?
Posted 23 April 2011 - 01:21 PM
Posted 23 April 2011 - 01:29 PM
I have just been informed that high oil pressure can cause high temps.
Edited by Ferretboy221, 23 April 2011 - 01:37 PM.
Posted 23 April 2011 - 01:30 PM
Edited by bmcecosse, 23 April 2011 - 01:32 PM.
Posted 23 April 2011 - 01:33 PM
Posted 23 April 2011 - 02:21 PM
Posted 23 April 2011 - 04:39 PM
Posted 23 April 2011 - 04:41 PM
Check you PCV system as it maybe blocked , also the installation of the incorrect oil filter can cause high oil pressure ( incase you have changed it recently ? ) or even a blocked filter and a dicky pressure relief valve could cause this problem too . Worth a wirl on those 2 if all else fails .
Posted 23 April 2011 - 05:10 PM
Posted 23 April 2011 - 11:14 PM
Would high oil pressure cause high water temps?
Posted 23 April 2011 - 11:22 PM
Posted 24 April 2011 - 10:33 AM
Are the guages electrical or mechanical?
Posted 24 April 2011 - 04:22 PM
Posted 24 April 2011 - 06:03 PM
