which is which cylinder
Posted 12 January 2006 - 12:30 AM
Posted 12 January 2006 - 12:34 AM
and firing order is 1 3 4 2 anti-clockwise and 1 is normally around the 1/2 o'clock postion on the dizzy.
Edited by GuessWorks, 12 January 2006 - 12:35 AM.
Posted 12 January 2006 - 12:39 AM
Only if when the engine has been re assambled the dizzy drive has been installed correctly1 is normally around the 1/2 o'clock postion on the dizzy.
Posted 12 January 2006 - 12:41 AM
Posted 12 January 2006 - 12:43 AM
Posted 12 January 2006 - 12:52 AM
No, cylinders from right to left in sequence. IE as you look at the engine with the rad on the right 4321being stupid i know but does that mean that the cylinder neaest the rad is 1 then next to that to the left is 3 , then net again is 4 and the furthest left is 2
Dizy cap 1342 anticlockwise.
Better to get the engine to top dead center at the start of combustion stroke. That is, timing mark (notch) on the pulley lined up with the long tooth on the cover with both the inlet and exhaust valves closed on number one cylinder( and that is the one next to the rad). Once this has been achieved remove the dizzy cap and see which lead on the cap it points to, as guesworks says most likely around about 2 o clock, but it is better to check as it is not that uncomon that the dizy drive is installed two or three teeth out either way.
Now you have found number one cylinder on the dizy cap, the next to that anticlockwise is number 3 and so on
Posted 12 January 2006 - 12:53 AM
Oh i think i get it now. They are in order from 1 to 4 but it counts from the radiator rather from the left. And the firing order is 1 3 4 2.
and that's why I said normally :cheese:
Posted 12 January 2006 - 01:03 AM
Posted 12 January 2006 - 01:11 AM
Posted 12 January 2006 - 01:46 PM
The points on my dizzy cap were looking a bit corroded and the rotor arm a bit grubby.
4 new spark plugs, a new cap and a new rotor arm later and it starts a dream. No point messing about with it for the sake of £20 or so.
Posted 12 January 2006 - 07:04 PM
