Help :sad:
I’ve taken the rusted hinges off my 2nd hand driver’s door
That I got off a mate for a £10, complete :tongue:
As he had plans to turn the mini into a trailer
But in doing so I’ve found this
(See pics)
The bottom corner was covered by a light skim of filler
Probably done when it was re-skinned
The rest of the door if rust free and sound
Can this be repaired or is it time to look for a new door?
Thanks,
<karl>
Help
1984mini25
, Jan 12 2006 03:39 PM
3 replies to this topic
Posted 12 January 2006 - 03:39 PM
Posted 12 January 2006 - 03:40 PM
Close up
Posted 12 January 2006 - 03:46 PM
The bottom corner that was coverd by filler :sad:
Posted 12 January 2006 - 04:34 PM
I had a similar problem with a second hand door that i bought. To fix it just carefully weld the cracked area back together. Before i did this i put a bolt in one of the hinge bolt holes to ensure that the bolt was exiting squarely. After this grind weld till flush and repaint.
Hope this helps.
Hope this helps.
