12g295 Cylinder Head
21 replies to this topic
#16 MRA
MRA
  • 7,607 posts
Posted 08 April 2016 - 06:23 PM
Unless you are going to thrash it long and hard - don't bother with unleaded (or additives) - set inlets to 12 thou gap and exhausts to 15 thou. But do measure the head thickness - if you have flat top pistons it needs to be ~ 2.710" inches, if dished pistons then go for ~ 2.670".
 Of course the information for dished pistons is dependant on the size of the dish and the bore size and what CR you require.
#17 MRA
MRA
  • 7,607 posts
Posted 08 April 2016 - 06:30 PM
Hi sorry to jump on this thread I am new to the forum. I want a little more out of my mini and have been told that changing the cylinder head is probably the best thing to do on a standard 998. I am pretty good at using a spanner and have done plenty of work on my mini before but have never ventured that far just need a bit of advice as i'd pretty much like to do a straight swap. and only really have to readjust the carb. so just wondering which head i could use to just do a straight swap, rough price and how much power it would give? I do not want loads of power but just a bit more that the normal mini has. Ive recently fitted a stage 1 kit so that should also improve it.
any advice would be much apreciated.
thanks Josh
:highfive:
A decent modified 998 head casting will give you benefits in both torque and power if done correctly, there are a few companies about that modify cylinder heads,
Keith at Calver Special Tuning, http://www.calverst.com
Swiftune, http://www.swiftune.com
Phil at Turbo-Mini, http://www.turbo-mini.com.html
to name a few of good ones.
#18 Joshua.w
Joshua.w
    Just On Tickover
  • 6 posts
Posted 08 April 2016 - 08:26 PM
thanks Josh
:highfive:
Hi thankyou for the links any idea how much they would cost?
Josh
#19 blacktulip
blacktulip
  • 6,224 posts
Posted 08 April 2016 - 09:23 PM
You need to work out your intended camshaft that you are going to use first. If standard you will need to atleast run a higher compression ratio to get anything from the head. If you have got dished 998 pistons I would advise against using the 12g295 head as you will need to skim too much off the head in order to get a good compression ratio. The problem with taking too much off the head means you risk going into the oil gallery in the head. There is a lot more to look at first before just changing a head otherwise you will end up disappointed with the results.
#20 Ethel
  • 26,074 posts
Posted 08 April 2016 - 09:39 PM
A 295 is certainly doable with dished pistons. I also wouldn't make any assumptions about any 295 you find, they've been out of production for decades and a top choice for modifying.
#21 MRA
MRA
  • 7,607 posts
Posted 10 April 2016 - 02:09 PM
Josh the cost is dependant on the spec you choose, any of the companies I mentioned above will advise you on a best choice for your engine specif you know it ?.
#22 limby2000
limby2000
  • 366 posts
Posted 10 April 2016 - 09:36 PM
I had 80 thou machined off my standard 12g295, and when we burretted it, it was only reduced to 24.5 cc , it still had potential for another skim but did,nt want to risk it.
