IMPORTANT:UPDATING TMF
#61
Posted 14 February 2006 - 08:48 PM
#62
Posted 14 February 2006 - 10:09 PM
*patience is a virtue*
the new site has only been up a few days, there are obviously going to be a few glitches, just be patient and it will all be sorted
NB: tried not to act the protective g/f
Im not worried i know it will be done, just very hard to find the post button! Ive faith in Nick!
#63
Posted 14 February 2006 - 10:33 PM
#64
Posted 14 February 2006 - 11:09 PM
#65
Posted 14 February 2006 - 11:19 PM
its going to take alot of man fat hours to get the show on the road propley
in other words in a couple od week if your haven problems then, then please contact us and we will sort it. but for now things will be poping up, going down changeing etc
we have alot planed for TMF and are doing our best not to distrube the main running of the club.
thanks for being pasiant.
its taken us along time to get this forum now lets show off what it can do... but in time lol
#67
Posted 15 February 2006 - 07:18 AM
From a systems designers point of view, not the smoothest changeover in the world, but if you can sort out the missing graphics before doing anything else, it would be of benefit to the user community...
1/2 the time I don't know if I clicked the right button or not.. and I'm sure I've nearly deleted a couple of topics..
I'm not having a go, but would advise getting the outward presentation working.. before adding new stuff.
#68
Posted 15 February 2006 - 12:14 PM
#69
Posted 15 February 2006 - 12:19 PM
#70
Posted 15 February 2006 - 12:20 PM
yeh but gw they cant be certian that all the images would switch with the changeover and you cannot run 2 forum softwares at once so u can not test it before it goes live.
or in guessworks talk
you can only fit one gear box at a time and you cant test the new gear box untill you remove the old box and fit the new one
if the new one doesnt fit your screwed
#71
Posted 15 February 2006 - 12:21 PM
You can run two forums at once, ive done it before all you need to do is install it to a different directory and there you go two forums at once, creates some small issues but for testing its wonderfull, i always do that at work, have the main system and in another folder the testing system for new components.
Nick told me invison helped him with a few problems on the forums and since then there has been no images, also the new version links to different table names than the old one, its not TMF fault its invisions for the upgrade!
Come on guys, Nick cant just drop everything to fix this site, he does have a full time job and other commitments.
If you wanted everything to go so smooth as you want you should have to pay so the admins can hire a webmaster!
You can run two forum softwares at once, just set them up in different folders. Can't have them both running off the same DB though I think. Actually you probably can (nearly anything is possible with the right knowledge), but would need some coding outside what the memebers of TMF know.
I know the code Jammy, im helping Nick when i can. Although its not so easy on a forum so big.
Jammy you can connect to the database from two forums by the way.
