wont start :(
4 replies to this topic
#1 waynie
waynie
  • 311 posts
  • Local Club: Need one! (In derby area?)
Posted 13 January 2006 - 05:26 PM
Hi one and all dad thought he'd have ago at getting the beast up and running, well it runs for 5-20 second intervals then as soon as you put on the accelerater it just cuts out. Dad thought it might of been lack of fuel, so i went to tesco got a £5's worth but still same prob :S any ideas?
cheers all
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 13 January 2006 - 05:28 PM
adjust the mixture sounds like it could be a possible
Also have you checked the timing?
#3 waynie
waynie
  • 311 posts
Posted 13 January 2006 - 05:32 PM
sorry :s my car knowledge is very limited. could you be in as much detail as you can so i can phone my dad up and read from your replys. cheers
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 13 January 2006 - 06:46 PM
Have you put oil in the carb dash pot??? thats the black knob on top of the carb
Ensure the ignition timing is right first then sort the idle spead, then the fuel mixture, then re adgust the idle
#5 blacktulip
blacktulip
  • 6,221 posts
Posted 13 January 2006 - 07:54 PM
just a thought but.... are you starting it with choke or does it do it once warmed up? check to make sure the choke is working propely i.e checking the cable isnt loose.
