Edited by mk3cortina, 16 May 2011 - 05:48 PM.
To Those Who Have Built Their Own Engine Frame/subframe
mk3cortina
, May 16 2011 05:48 PM
3 replies to this topic
Posted 16 May 2011 - 05:48 PM
im going to be putting an order in tomorrow for the box section i will be using to fabricate my engine cradle from to mount it to the front subframe. but was wondering what type of box section i will be best using. 2"x2", 1"x2" etc etc, i think thickness wise ill use 3mm.
Posted 16 May 2011 - 06:01 PM
i used 20 x 50 mil box yet to test it but i think its plenty as long as it gusseted in rite placesim going to be putting an order in tomorrow for the box section i will be using to fabricate my engine cradle from to mount it to the front subframe. but was wondering what type of box section i will be best using. 2"x2", 1"x2" etc etc, i think thickness wise ill use 3mm.
Posted 17 May 2011 - 10:22 AM
3mm I assume you're meaning wall thickness. That's a bit OTT and will add one hell of a lot of weight - generally spaceframe stuff uses 1.6mm wall tube.
25x25mm box and 25x50mm box is what I've used for my spaceframe - what you'll need will depend on your design.
Iain
Iain
Posted 17 May 2011 - 06:03 PM
Agreed ^
