Spi Fuel Pump Fuse Blown
Posted 16 May 2011 - 07:34 PM
Posted 16 May 2011 - 07:36 PM
Posted 16 May 2011 - 07:43 PM
Check the inertia switch on the bulkhead passenger side.
Thats the little black box by the windscreen wiper motor? If so i pushed it in a few times and still nothing
Posted 16 May 2011 - 08:12 PM
Posted 16 May 2011 - 08:29 PM
Disconnect the wiring at the pump, a duff pump will blow the fuse, check wiring with volt meter
With the ignition on you should have power, after around 3-5 min it should loose power because the engine has not started.
john
Posted 16 May 2011 - 08:56 PM
Posted 16 May 2011 - 09:09 PM
hi
john
Disconnected the white with brown strip wire and black from the very top of the tank... only wires i can see going to it, so im assuming these are the electrical connectors for the pump and there is only 0.006 volts between these wires even just seconds after turning the ignition on. Could this mean there isnt a problem with the pump but a power issue instead?
Posted 16 May 2011 - 09:10 PM
There are several areas you need to check first. The relay pack, the bulkhead 13 way connector, the inertia switch and its connector, the 13 way connector under the passenger side dash, the wiring that runs along the passenger side floor into the passenger side rear bin, over the wheel arch into the boot.
I have just pulled my wiring loom apart and found scortched wiring for the fuel pump on the 13 way connector under the passenger side dash, and I previously repaired scorched wiring on the 13 way connector on the bulkhead.
The fuel pump wire colours, from relay pack to bulkhead 13 way connector - Brown/ Slate. From bulkhead 13 way connector to fuse 11/ 24 way fuse box - Brown/ slate. From fuse 11/ 24 way fuse box to Inertia switch - Brown/ Slate. From inertia switch to under dash 13 way connector - White/ Purple. From under dash 13 way connector to fuel pump - White/ Purple.
Fuse should be 10 amp from memory. The wiring to the pump is not that fat, so don't go jamming a 20 amp fuse in there!
Break it down into parts and test the parts.
Posted 16 May 2011 - 09:12 PM
Posted 16 May 2011 - 09:17 PM
hi
john
The Rover MEMS energises the fuel pump for a few seconds when the key is turned to ignition. It then waits for activity on the crank sensor showing the engine being turned over before it energises the pump again.
Testing the fuel pump in this manor will require a second pair of hands. One person using the multi meter to check for voltage at the pump connector (fuel pump disconnected) while the other turns the engine over.
Posted 16 May 2011 - 09:36 PM
Thanks for your help so far!
Posted 17 May 2011 - 05:48 PM
Posted 17 May 2011 - 05:51 PM
Thanks.
Posted 17 May 2011 - 06:30 PM
The clicking is coming from the unit under where the accelorator cable is connected, the clicking can be started by turning off the engine or repeated movement of the accelorator. The clicking inturn moves a small shiny metal pin highlighted in the pic below.
With the ignition off the the pin sits half way out, turning off the ignition on moves it all the way out, turning off moves it back to half way after the clicks. If the accelorator is moved repeatidly the pin moves fully into the rubber housing.
Could this be the cause of the fuel pump not starting up when the ignition is turned and why the engine wont start, is this another problem or is this normal
Edited by scubalegg, 17 May 2011 - 06:34 PM.
Posted 17 May 2011 - 06:44 PM
