Specialist Components Typhoon Ecu
21 replies to this topic
#16 JSnowDude
JSnowDude
  • 110 posts
Posted 20 June 2012 - 04:04 PM
I'm currently running around 76bhp last time it was on the rolling road, would this system be more of a benefit if the engine was in a higher state of tune ie reaching the limit of the MEMS capability which I believe is around 85bhp from other posts i've seen. Or would I see a benefit in it's current state of tune witha rolling road session once installed?
#17 timecott01
timecott01
    Starting My Mini Up
  • 2 posts
Posted 12 July 2012 - 04:32 PM
I have just fitted a Typhoon ECU using the SPi plug-play kit. My engine is a bit modded:
Richard Longman GT6/6 (5port) head
Swiftune 1293 block/crank etc. balanced.
Piper 255 cam
roller 1.5:1 rockers
I have been using the standard rover mems ecu up to now.
The guys at SC supplied me with a .cal file which was thought to be a reasonable match for my engine. It runs ok at high revs but seems to run way too rich at low revs and tends to stall. i appreciate this is all fixable if i get the right mapping.
Would like to possibly compare/swap mapping info? CIAN above - are you up for emailing me your .cal file??
Is there a forum specific to users of this ECU on the Classsic Mini - or is this it??
#18 icklemini
icklemini
  • 2,982 posts
Posted 12 July 2012 - 09:39 PM
Piper 255 cam
Get it on the rollers and get it mapped to your engine??
#19 timecott01
timecott01
    Starting My Mini Up
  • 2 posts
Posted 13 July 2012 - 09:06 AM
this is probably the most sensible and quickest solution (if a little costly) but i wanted to try various mini-spi-based maps, and get an idea of the characteristics of each from driving the car....and then try to develop my own map..!
#20 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 14 July 2012 - 02:43 PM
Timecot i thought the same thing but looking at the software and all the drop menues i just left it alone after it was mapped lol! It is an expensive mod but i would highly recomend it dump the rover unit!
#21 mini13
mini13
  • 3,811 posts
Posted 14 July 2012 - 02:59 PM
seriously, get SC to set it up,
they were fast and thorough with a freinds 8v bmw headed MPI
#22 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 23 July 2012 - 01:22 PM
i have this ECU... dont use it very much though, when i first got it it caused my car to stall if i let revs drop to an idle, but i emailed SC who where very helpfull and offered for me to go to them and have them get it so it would work (not tune it) just so i could see that the ECU was perfomring correctly, you can notice a difference and to me a very good bit of kit
