flywheel removal
Posted 14 January 2006 - 08:39 PM
what do you all think of the minispares flywheel puller i'm about to buy one?
thanks lee
Posted 14 January 2006 - 08:42 PM
get a long socket wrench long enough so that as the bolt spins the wrench is going to hit the floor (asuming engine is out of car) therefor wont turn anymore, thats how i did it anyway
Gaz
Posted 14 January 2006 - 08:44 PM
Posted 15 January 2006 - 12:28 AM
thanks lee
Posted 15 January 2006 - 09:27 AM
Just be careful you don't knock the flywheel off !!!stick a screw driver thru where the start motor would be (hence remove it) to lock flywheel
Posted 15 January 2006 - 11:25 AM
But not everyone has a garage full of 'special tools'.
Posted 16 January 2006 - 10:49 PM
thanks lee
Posted 16 January 2006 - 11:44 PM
if the flywheel is off then a flat bar across the slot in the crank tail and jammed up/held should do the trick
TTFN,
Dave
Posted 17 January 2006 - 07:33 AM
I must admit even I use a screwdriver (have a knackered old one just for the job) , just too lazy to weld a bit of steel onto a bar.. but that's all the locking tools are...you can buy a proper flywheel locking tool for this job, rather than a screwdriver, it bolts into the starter location and then locks onto the flywheel teeth! :wink:
Posted 17 January 2006 - 05:55 PM
i can get the cam gear and chain to slide up and down but the chain is obviously holing it on its the little woodruff key thats holding on tight...
any ideas?
thanks lee
Posted 17 January 2006 - 11:08 PM
lee
Posted 17 January 2006 - 11:54 PM
you'll have to pull them off 'squarely' as the chain will lock up and you'll have to pull on the other one off a little.
if you have no tyre levers then a 3-legged puller would do the same job (watch the thread in the crank though!)
(technically the woodruff is there to position the gears - it doesnt drive them - the nuts holding it all together does that)
TTFN,
Dave
Posted 18 January 2006 - 11:21 PM
