hi all i have a mini sprite spi which i have converted to a weber carb, i have a new front wiring harness in it and all is connected up fine but i have a problem when i turn the key to start the fuses are all fine and the relay switches but al i get from the starter is the solenoid engaging the gear into the ring gear it doesnt turn the starter.
Now i have checked the relay is giving power i have cleaned all the earths up, given direct power to the starter to check the starter isnt seized and it works fine so i dont know why it isn't sending the power across.
Any help would be much appreciated
cheers dan
Problem With Starter
danny164
, May 22 2011 04:39 PM
No replies to this topic
