1971 Clubman Estate....now Turbo
#76
Posted 22 January 2012 - 10:12 AM
How much did the compleate front end set u bak? Inners too
#77
Posted 22 January 2012 - 10:30 AM
Good luck with it all! :)
#78
Posted 22 January 2012 - 07:17 PM
Stunning work there. You've got some skills mate.
What type of bolts did you use for the accelerator pedal repair at the bottom of bulkhead? I had the same issue. The originals have a round flat head to clear the subframe. I experimented with all sorts but in the end just made use of the originals as they weren't too bad. Also did you have to swap the tube from the old panel, that holds heater air pipe, on the right hand inner wing, or did you make a new one? Mine was too bad to reuse so I made my own as the inner wing doesn't come with one. See my Leyland Mini 1000 thread and towards the bottom of page 3 to see what I mean.
Anyway great work and an extremely interesting read.
Thanks. For the accelerator pedal repair I just used 1/4" UNF bolts I believe. Welded them on from the back, and then took the tops off with a grinder.
I didn't grind them all the way back, I left about as much material as there is on the standard bolts.
As for the sleave thing on the inner wing for the heater pipe, my inner wing came with it already attached.
I had a flick through your build thread, all I can say is WOW. Your fab skills are amazing.
Top work there!
Can't remember off the top of my head but it was a lot, even more so because it's a Clubman front end.
Hey wow that was a bash, just read through this build, and its a lovely clubby estate mate, i have bashed mine bought 5 months ago, but the damage was more to just the left hand side but still looked bad, only just got all the front rebuilt again. I will keep an eye out on this build!
Thanks man.
I remember seeing your estate at 'Mini's By the Sea' in Worthing last year, I was there with the flame.
Do you have a build thread for it?
Liam
#79
Posted 25 January 2012 - 08:53 PM
They seem to be in really good nick no signs of rust along the tops and bottoms.
To be fair the doors on the car aren't to bad and are easliy repairable, just these went for a decent price and will also save me a job.
Big thanks to my dads mate Simon for collecting them.
Sorry about the bad photos.
Liam
Edited by woodenman23, 25 January 2012 - 08:53 PM.
#80
Posted 25 January 2012 - 09:22 PM
Keep up the good work - I know how hard it is.
Hugh
#81
Posted 28 January 2012 - 12:42 AM
I had a flick through your build thread, all I can say is WOW. Your fab skills are amazing.Top work there!
Can't remember off the top of my head but it was a lot, even more so because it's a Clubman front end.Hey wow that was a bash, just read through this build, and its a lovely clubby estate mate, i have bashed mine bought 5 months ago, but the damage was more to just the left hand side but still looked bad, only just got all the front rebuilt again. I will keep an eye out on this build!
Thanks man.
Liam
Hi yeah it was a the minis by the sea lol got a few looks, thought we would do somthing crazy before it came off the road! i have started a build thread hoping to get on with him as soon as i can miss him on the road
#82
Posted 28 January 2012 - 12:53 AM
I know what you mean, mines been off the road for around around 9 mounths. I much prefer my estate to the flame.
#83
Posted 05 February 2012 - 06:14 PM
Sorry not much of an update, I'll do one for what I did today later when I can be arsed to upload the photos.
Edited by woodenman23, 05 February 2012 - 06:17 PM.
#84
Posted 05 February 2012 - 06:29 PM
#85
Posted 05 February 2012 - 06:52 PM
#86
Posted 05 February 2012 - 07:51 PM
Started off with a clean up of the garage and the car, as I made one hell of a mess in there the other day.
The days aim was to do some alignment checks. Should have done this right at the beginning but keen to start the project meant it slipped my mind. Anyway better now than never.
Car lifted off the home made trolley and put on axle-stands, then the rear subframe was bolted in.
Before starting the alignment checks we had to make sure the car was level.... this took some time.
Father giving me a hand.
We dropped the plumb bob from the centres of the:
- Front subframe front mounting bolts
- Front subframe rear mounting bolts
- Rear subframe front mounting block lower bolts
- Rear subframe rear mounting block bolts
You can just about see the eight makings on the floor.
What you are looking for when doing this is for the diagonals to intersect the centre line at the same point.
This shows that the front subframe is true, which was a bit of a surprise considering as it is the same one that was fitted when the accident happened. I have got to admit I was a little nervous during this process.
This is the most important intersection as tells you if there is any distortion in the shell, again I was happy to see the lines met.
Finally the rear subframe.
Looks a little like some Voodoo crap.
Liam
#87
Posted 05 February 2012 - 08:13 PM
Liam
#88
Posted 05 February 2012 - 10:15 PM
#89
Posted 06 February 2012 - 11:50 AM
looking good mate! doing a fine job of repairing your estate! when are you hoping to have it finished? or is it just as and when?
As and when really. This is my first rebuild so I'm taking my time with it and there is the issue of funds.
#90
Posted 06 February 2012 - 12:44 PM
Thanks guys
looking good mate and just one thing your not taking your time you wizzing through it Haha
