Speed increase humm no but it could have done as it was running stright now.
Not sure were speed increase came from, but what I actually meant was better acceleration, not increased acceleration, just better due to less weave...
Anyone who actually knows about steel, will tell you how very rare it is to get steel bar of any diameter that is straight, straight by eye is not straight when it comes to compressive forces acting on the ends, the bars do bend in use, and yes a lot of the issues may well be down to the tie bar bushes as well that I grant you.
On the other hand fitting uprated bushes to standard tiebars is still not a good thing to do, just because someone has done it for 6 years.... doesn't mean anything without the actual mileage and road surfaces being considered....... how many of you have broken a piece of metal simply by bending it back and forth ?? This is exactly what is happening with your tie bars, the more rigid or stiffer the bushes used the more flex the bar has to cope with, more importantly the point at which plastic deformation occurs, this is the point at which fatigue starts to take effect.
How many people have had a broken tie bar due to a fatigue failure...... ?? Who knows ?? anyone ?? and how many of those can no longer answer ?
If the aforementioned tie bars have been fitted for 60 years and not moved then no problem (well except for the added corrosion), however if they are used on a rough road every day then you are playing with fire.... when they eventually fail will you come back on to this forum and tell us ? more importantly would you able to ??
As a sales pitch ??? not at all and all those who actually know me would also say that I would rather see a customer again than in a hole in the ground.
And yes I have had a head on collision with a 40 tonne lorry in a Mini, Police reports were approximate impact speed of 40mph, one uprated tie bar bent like a banana the other side the actual bottom arm was ripped off the subframe tie bar intact, except a little bend.
