Bodywork Where Accelerator Pedal Mounts
22 replies to this topic
#16 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 31 May 2011 - 06:05 PM
I have had it to my local classic mini garage 'green & whites' He says he can see daylight where there shouldnt be. Goes in next wed and he his stripping it and welding it up for me :thumbsup:
Didnt want to risk it due to all the fammable gasses and materials in the area. he said it will be a pain in the arse to do but will give it his best shot
Another local, i'm in middlesbrough hopefully see you about.. (sorry to be off topic)
Dan..
#17 lionmod_boy
lionmod_boy
  • 72 posts
Posted 31 May 2011 - 09:11 PM
nope no quote, maybe a bit silly on mybehalf but ill just be happy knowing its getting done right
#18 lionmod_boy
lionmod_boy
  • 72 posts
Posted 31 May 2011 - 09:13 PM
yea hopefully :proud:
#19 Adamjsimpson
Adamjsimpson
    Starting My Mini Up
  • 2 posts
Posted 20 November 2015 - 10:45 PM
I know it's been a good few years or so but I have the same problem. If I pull the pedal towards me it feels like I could pull the bracket away from the bulkhead.
Did you cut out and plate? If so are the studs attached to the bulkhead or do they bolt through from the outside?
P.s I'm new to all this, bought my first mini this week
#20 Daz1968
Daz1968
  • 2,058 posts
Posted 20 November 2015 - 11:54 PM
M machine do repair panels for this area, but they are easy enough to make up yourself as well
#21 nicklouse
  • 18,598 posts
Posted 21 November 2015 - 12:09 AM
It kinda depends on what is actually gone.
There are a pair of weld studs that go through from the engine bay. Then there is the actual pedal bracket and the bulkhead.
Some are easier to fix than others.
#22 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 21 November 2015 - 07:03 AM
I've just bought this repair panel from somerford cost 16.20£ + postage for the van special order as I believe it's a m machine part
#23 Adamjsimpson
Adamjsimpson
    Starting My Mini Up
  • 2 posts
Posted 03 December 2015 - 08:51 PM
It's the bulkhead thats gone, behind the bracket/plate. If I pull on the pedal the plate, nuts and studs all pull away from the bulkhead slightly
