Rear Hilo Adjustment
Posted 31 May 2011 - 08:46 AM
Year: 1977
Fitted HiLos to rear on the Estate at the weekend but have had a bit of trouble dropping the rear height to the matching front height.
When I wind down length of the HiLo the whole unit just falls out of position as when jacked up all pressure is taken off and the HiLo just falls out, what am I doing wrong here?
I fitted them following the how-to guide on here in the FAQs, knuckle, HiLo, new rubber cones. They are currently fitted as short as I can get them without them falling out but the rear is currently sitting two inches higher than the front with a huge arch gap.
Any ideas on what I'm doing wrong?
TIA
Posted 31 May 2011 - 08:50 AM
Not sure on estates but on the saloon I can just about get at the adjusters with the wheels on. So If you can reverse up some wheel ramps can crawl under and adjust with the weight of the car holding it all together.
Posted 31 May 2011 - 09:01 AM
The argument being, that the cones wil be causing the excessive ride height. in the next two weeks they will settle and squash a bit, then you an use the hilo adjustment.
In my opinion if the hilos are falling out when the weight is taken of the suspension, then that aint safe!
Posted 31 May 2011 - 09:18 AM
Exactly my thinking, I won't be shortening them any further as I don't want them falling out of position when the weight is taken off the suspension. I'll have to ride around with them sitting high for a while until they settle down but I can't really see them settling down 2 inches!
Posted 31 May 2011 - 09:53 AM
What sort of gap have you got between wheel and arch?
Posted 31 May 2011 - 10:04 AM
The centre of the arch sits about 22" from the ground where as on the front it's 20". I'm hoping to get the rear down at least an inch.
Posted 31 May 2011 - 10:20 AM
either way a little 'settling' of the cone equates to quite a bit.
Posted 31 May 2011 - 11:20 AM
i helped fit the front high los and shocks to maggies minders mini and it was riding high befor we took a test drive to the pub then all of a sudden they started to lower, so by the time we got back to the cars his was sitting at a lower height. like said might just need settling in.
Posted 31 May 2011 - 06:48 PM
What is the ratio for lowering the rear? is it 1:3 or 1:5?
Its 1:5 on the back and 1:3 on the front.
Posted 31 May 2011 - 07:43 PM
Posted 31 May 2011 - 08:27 PM
Posted 31 May 2011 - 08:33 PM
Maybe you need shocks for lowered suspension....may stop your springs/hi-los from dropping out when jacked
I thought that but I'm not trying to go too low so wouldn't of thought I needed them just to go down an inch or so!
Posted 01 June 2011 - 03:31 PM
You can also lockwire the hilo to the back of the subframe (not tight though!!), this will also keep in in place when the wheel droops...
Posted 18 August 2011 - 09:16 PM
Posted 19 August 2011 - 06:20 AM
