Very Sensitive Throttle
Posted 02 June 2011 - 12:23 PM
the throttle pedal on my mini is very sensitive...
is this normal?
if not, what can I do about it?
thanks!
Posted 02 June 2011 - 12:33 PM
If i'm wrong i'm sure someone will correct me!
i know with a HIF44 carb, the way it works is designed to give you more control at low throttle and less at high throttle because of the shape of the 'butterfly lever'
Posted 02 June 2011 - 12:39 PM
although there is a tiny bit of play in the pedal which suggests it might not be the cable...
I think
Posted 02 June 2011 - 12:40 PM
just a super powerfull mini!! lol
If it's from near idle, it could be an induction air leak - the effect becomes less as the throttle opens.
If it's just the instant you touch the go pedal, you might need to look at your engine stabiliser(s) & mountings.
Of course, those dinky pedals don't have as much travel as most of the big, lardy, modern motors either.
Ditto, the sticky/tight cable and or pedal others have suggested too.
Posted 02 June 2011 - 12:41 PM
I suppose the cable could be a bit tight...
I think
the cable is supposed to be tight. you dont want slack in it. otherwise you'll get nothing until the cable goes tight, then the same sensitivity as you had before!
Edited by MattEvans, 02 June 2011 - 12:43 PM.
Posted 02 June 2011 - 12:44 PM
it's a 1990 checkmate
single hs4 carb
Posted 02 June 2011 - 12:47 PM
Posted 02 June 2011 - 12:56 PM
Posted 02 June 2011 - 01:28 PM
of the oil in the dashpot affect the
sensativity
Posted 02 June 2011 - 03:08 PM
dont the viscosity sp?
sensativity
Check to make sure you've got oil in the dash pot and renewing it could help with some thicker stuff.
Posted 02 June 2011 - 03:18 PM
how much should be in the dashpot?dont the viscosity sp?
sensativity
and how can I tell when I've got enough?
Posted 02 June 2011 - 03:23 PM
Hi,
Stop picking on it then. We can all be sensitive at some time or another, a nice warm loving hug may help.
