Oil catch tank
johnnysti
, Jan 17 2006 05:29 PM
9 replies to this topic
Posted 17 January 2006 - 05:29 PM
Hi all
Anyone know of a good place (like ebay!!) to get an oil catch tank? Does anyone have any pics of one in situ?
Johnny
Johnny
Posted 17 January 2006 - 05:30 PM
errrrm Ebay?
Posted 17 January 2006 - 05:38 PM
Posted 17 January 2006 - 05:47 PM
hmmmm what do these do?? :erm:
Posted 17 January 2006 - 06:30 PM
sits between breathers and carb so none of the carp goes into carb or onto road / track if breathers arnt connected.
Posted 17 January 2006 - 11:18 PM
for ease, make sure you pick one up with a visual gauge. much easier than having it leak everywhere once it fills up. If you can, see if it has an outlet on the bottom too so you can use a tap to drain it (rather than take it off to drain it)
Posted 17 January 2006 - 11:24 PM
Hi all
Johnny
thats where i managed to get mine to fit, hadn't got the pipes sorted at the time of the pic though. goit it off ebay for about £30 i think.
Posted 17 January 2006 - 11:50 PM
if you do fit it in series with the carb then it must be air tight.
with the breathers - you either connected them all to the carb in an air tight fashion - or block the carb 'nipple' off and vent the breathers to air / catch tank.
dont have one breather to 'air' and the other to the carb as you'll create a massive air leak - the carb will draw air through the open breather, through the crank case and through the carb-connected breather into the carb - not good!
TTFN,
Dave
Posted 18 January 2006 - 12:02 AM
i use a coke can and bit of hose pipe! Hasnt let me down yet!he he
