How Do You Pocket A Block?
#16
Posted 15 June 2011 - 02:55 PM
#17
Posted 15 June 2011 - 03:10 PM
#18
Posted 15 June 2011 - 03:12 PM
Do you mean like this one....
[attachment=113568:IMG_0784.jpg]
Well this one was done on our CNC mill
It depends on how good a job you want ? some people have apparently used a dremmel, however accuracy will be sadly lacking
Thanks for the photo and info! How much roughly would this cost to do properly? If the engine was still in the car when taken to the machine shop.
It will cost a lot more than £60 if the engine is still in the car when you take it to the machine shop.... and that is assuming that they will even bother to do the job, taking engines out is not normally associtaed with machine shops.....
Right, ok thanks for the information on this. Its a fairly large undertaking by the sounds of it then!!!
From the photo posted earlier i can see the cutouts in the block but how big do they actually need to be?
#19
Posted 15 June 2011 - 03:15 PM
cheers,
piggybank is getting SMASHED UP! haha!!
#20
Posted 15 June 2011 - 03:30 PM
What is pocketing? In lehmans terms!!
hi
just means making space in the block for the valves to go up and down, as the 998 and1275 head have different spacing(lehmans terms)
Imo not worth the trouble, fit a complete 1275 and go
John
see that comment annoys me abit
1275 are expensive and may go quite quick but its still not like a 998
i would rather drive a 998 or 850 over a 1275 any day of the week
but thats My Opion
#21
Posted 15 June 2011 - 04:40 PM
The other point on a 998 with a 12G940 head fitted is that the insurancwon't change much..... as it is still a 998
#22
Posted 15 June 2011 - 05:21 PM
#23
Posted 15 June 2011 - 06:07 PM
I have no issues with my 1380 turbo engine either....
Is that a 1380 turbo AUTO or have turned traitor?
#24
Posted 15 June 2011 - 06:13 PM
No Paul that one has never been an auto.... it is 6 speed though
about 998 reliability over a 1275, i was told that as the bores are smaller this means there space between them is much thicker and leads to less engine failure through metal fatigue, and that they can take much more of a pounding than a 1275 can without it going pop, and also less likey to blow a headgasket? someone clevere than me will prove if this is bullpoop tho?
Do you still believe in fairy tales ?
#25
Posted 15 June 2011 - 06:19 PM
Sorry have I gone off topic?
#26
Posted 15 June 2011 - 06:20 PM
Do you still believe in fairy tales ? if you made a 998 and got it up to 150bhp...... like some of the 1275/1380 etc.. then you would also experience a similar amount of potential reliability issues...
perhaps they should put this on general ignorance on QI
#27
Posted 15 June 2011 - 06:24 PM
Why ?
#28
Posted 15 June 2011 - 07:29 PM
hi
John
i would rather drive a 998 or 850 over a 1275 any day of the week![]()
but thats My Opion
Witch is kind of the reason why I also stuck with a 998, but pocketed and fitted with an mg metro cam and 12g940 head.
The basic engine itself was practically free, the head and cam were £60 tops, add in the gearbox refurb, new bearings, piston rings, gaskets etc, etc. I ended up with basically a rebuilt 998 for the same amount, as a shagged 1275 would sell for. As in my mind having stripped down a few supposedly good running engines (mostly for parts) there no such thing a decent used engine that’s ready to drop straight in.
#29
Posted 15 June 2011 - 08:08 PM
Why ?
general ignorance is a thing on QI where they ask a question that everyone thinks is common knowledge and the answer is always not what they think it is
#30
Posted 15 June 2011 - 08:16 PM
Why ?
B***** h*** I didn't think you were going to say that
