Advantages/disadvantages Of Acid Dipping
#16
Posted 17 June 2011 - 09:13 AM
#17
Posted 17 June 2011 - 09:15 AM
We use different media for different jobs and some can be severe and others will not damage the surface at all its really about what yo uwant to spend and how good you want it to look ??
#18
Posted 17 June 2011 - 09:18 AM
#19
Posted 17 June 2011 - 09:19 AM
Sorry for saying it, really just trying to help but reiterating how clean a engine needs to be before being re-built, no point doing a half assed job, especially if you're spending cash on it...
You shouldn't be sorry for saying it ? clean and re-clean .... and when it's clean enough clean it again to be sure... it's a lot of money to throw away for a bit of cleaning material and time...
#20
Posted 17 June 2011 - 09:21 AM
#21
Posted 17 June 2011 - 09:43 AM
#22
Posted 17 June 2011 - 09:48 AM
#23
Posted 17 June 2011 - 11:19 AM
#24
Posted 17 June 2011 - 11:37 AM
Regards Blue
#25
Posted 17 June 2011 - 11:46 AM
#26
Posted 17 June 2011 - 12:16 PM
#27
Posted 17 June 2011 - 12:24 PM
#28
Posted 18 June 2011 - 07:58 PM
There are industrial cleaners that will wash your engine in a hot detergent , they use much the same chemicals as a home dishwasher and do a great job .
I would paint stripper the outside , strip block ,remove gallery plugs and core plugs ,etc . Then give it good prod about inside the gallerys with a long thin brush and parrafin .
Once as clean as you can get it then have it hot washed , please note that the block will begin to rust very quickly when removed from the hot wash , forming first on the aformentioned accurately machined areas , so get it back together and oily as soon as possible ,if painting the outside first prime with acid etch primer that is compatable with your final coat of paint ,the paint will adhere much better .
#29
Posted 19 June 2011 - 07:21 AM
Then they are using the wrong cleaning agent... I know of several companies that use normal dishwasher tablets, however these apparently contain salts in them, we use a mixture of 2 liquid cleaners specially developed for metals, without any rust forming.
