Windscreen Trim Replacement
Posted 21 June 2011 - 06:06 PM
Posted 21 June 2011 - 06:20 PM
Posted 21 June 2011 - 06:32 PM
Beg borrow or buy the tool, Im down to about 15 minutes for a screen now
and lube is the key
Posted 21 June 2011 - 06:38 PM
Ps we sell both tools....
Edited by mra-minis.co.uk, 21 June 2011 - 06:38 PM.
Posted 21 June 2011 - 06:45 PM
Hot soapy water (weak washing up liquid and the bestter the tool the easier the task.... and less liklihood of cracking it too
If you can beat the eBay tenner price I'll have one
Posted 21 June 2011 - 06:59 PM
Best quality Windscreen Tool
Or there is the cheapo one that well you have to struggle a lot with it, however it is better than a screwdriver.....
Screen Tool for UNDER a tenner
Posted 21 June 2011 - 07:04 PM
http://cgi.ebay.co.u...50#ht_500wt_922
Posted 21 June 2011 - 07:06 PM
Would question the washing up liquid though (appreciate you said weak solution Martin). When I did mine the washing up liquid caused some marks on my paint a few days after.
It was suggested to use car shampoo and I have used this since without issue.
When you put the strip in, leave a small gap and fill with sealant. Stops water getting into the inside of the strip and causing black marks. (been there done that)
Good luck
Regards
Steve
Posted 21 June 2011 - 07:13 PM
+1 for the correct tool.
Good luck
Regards
Steve
Yes I would agree, as car shampoo is designed for paintwork a much safer solution (no pun intended)
Posted 21 June 2011 - 07:18 PM
You can get a similar one with a roller attached, pushes the bead in as the tool spreads the rubber
Posted 21 June 2011 - 07:31 PM
Posted 21 June 2011 - 07:44 PM
Posted 21 June 2011 - 08:42 PM
Posted 21 June 2011 - 09:03 PM
Any tips - I've got a rear screen to do now (and a front screen when I dare look at the rust under the seal!!)
Steve
Posted 21 June 2011 - 09:21 PM
Front and rear screens fit the seal to the frame, wet it with your chosen lube
Fit the screen into the bottom of the seal, then work your way round with a small screwdriver and peel the seal over the glass.
Then fit the filler strip using the famous tool
