Some may wish to agree or disagree with Mr Calvers view on the state of the diminishing stock of 12G295 (which must have got considerably worse since he wrote the article 10 years ago) v his suggested alternative
Calver Article
Posted 23 June 2011 - 03:51 PM
Posted 23 June 2011 - 06:52 PM
Ebay linky
Buy these, no skimming required.(OR find some that are sensibly priced!)
Posted 23 June 2011 - 07:07 PM
Posted 29 June 2011 - 08:22 PM
There is an oil feed hole which goes downwards from the top of the 295 head. You measure the depth of this hole with a digital vernier and subtract the depth from the thickness of the head as you also measure that. The difference should not be allowed to go below 0.050", although i've known it to go to 0.040". The problem now is that most 295's have been skimmed once or twice during the past 40 years, so standard it probably won't be.
It is almost always possible to get an acceptable C.R. even on a 998 with dished pistons. I once skimmed 0.070" from a 295 to get 10:1 CR.
Said it before, that is a standard head NOT a 12G295 !
A 295 has approx half inch before you touch the drilling...................
Posted 29 June 2011 - 08:24 PM
Ebay linky
Without gudgeon pins they are not worth a lot really. A better buy would be the currently available flat-tops.
If building an engine properly the volumes should still be measured, the calculations done after the 'trial-build', then any machining done to get the C.R. correct.
Those D-tops are standard, so if needing to re-bore, as you would with any new engine build, it would be necessary to sleeve back to standard bore. So it would not be cheap.
Posted 29 June 2011 - 08:56 PM
Posted 29 June 2011 - 09:07 PM
Just for info - the 998/1098 engines NEVER had the spider drive oil pump - they were only for the 1275 (and yes 970/1071S) engines.
Edited by mra-minis.co.uk, 29 June 2011 - 09:08 PM.
Posted 29 June 2011 - 09:16 PM
Ebay linky
What currently available flat tops ??? (AE) Federal Mogul have stopped making them .. never come across such a crappy company in my life... especially after the Manager in charge of aftermarket sales Europe told me this would never happen![]()
Edited by Cooperman, 29 June 2011 - 09:22 PM.
Posted 29 June 2011 - 10:53 PM
Posted 30 June 2011 - 07:16 AM
Posted 30 June 2011 - 05:40 PM
Edited by stickycreambun, 30 June 2011 - 05:42 PM.
