Headlights Work But Sidelights And Rear Lights Won't
Posted 23 June 2011 - 10:14 PM
I have an Austin Mini Mayfair 1987 and when i turn my lights on only the front lights work. If i flick the switch to sidelights i get nothing. Sometime they work though. The problem is getting really frustrating as when i park up if i come back to my car i dont know if my lights will work or not.
Does anyone have any ideas of how to fix this?
Really want my sidelights to work!
Posted 24 June 2011 - 06:44 AM
Maybe get to your fuse holder, and give all of the contacts a good clean, (wirers to box, and box to fuses).
Dave
Posted 24 June 2011 - 09:52 AM
I think you'll find they share a fuse, do your dashboard lights work too?
Dave
I thought the headlights weren't fused through the fuse box?
My dash lights don't work either.
I have a new fusebox so will swap it over and see if that helps.
Posted 24 June 2011 - 10:08 AM
You could try removing the light switch and bridging the connections as a test: brown is live, red sides, blue heads.
Posted 24 June 2011 - 10:28 AM
I think Dave means the side 'n tails share a fuse - along with the dash illum and number plate lights.
Ok will try bridging the connections first to eliminate a fault with the switch then I will have a look at the fuse box.
Does anyone know which fuse the sidelights run through, will check the spade connector before I fit my new fusebox.
Posted 24 June 2011 - 10:54 AM
Posted 24 June 2011 - 11:26 AM
Posted 24 June 2011 - 11:42 AM
I believe the fuse for the sides, rears, dash and number plate lights is the second or third fuse as my girlfriends car had the same problem.
How did you fix it? Was it the fuse box?
Posted 24 June 2011 - 11:56 AM
Posted 24 June 2011 - 12:37 PM
Dave
Exactly my point, the dip beam doesn't go through the fuse box, but the rest that aren't working do, so check that
It's a known issue with them, and it won't hurt to just take the fusebox apart and clean all the terminals anyway, just make sure you know where they all go back!
Dave
Posted 24 June 2011 - 02:54 PM
Hopefully that's fixed the problem, if not then I'll have to either clean or replace the switch.
The old fusebox was green and corroded underneath so definitely needed doing!
Cheers for the info and help guys!
Posted 24 June 2011 - 05:04 PM
That green scum is the copper oxide, (essentially like rust but on copper).
Same as rust it doesn't conduct electricity, so your lights failed.
While you are at it, I'd recommend looking at the bullet connectors under the bonnet slam panel / behind the grille.
Take them apart and give them a quick clean with some emery cloth, keep everything in tip-top condition!
Enjoy your mini-ing!
Dave
Posted 18 June 2012 - 10:30 PM
I know this is an old forum but my mini is suffering the same problem !
Should i just take the fusebox out and give it a good clean? I thought the tail and side lights were on one of the line fuses so surely cleaning the fusebox wouldnt help?
I'm confused
Posted 18 June 2012 - 10:46 PM
Posted 19 June 2012 - 08:20 PM
On mine its the 3rd fuse down from the top, its one of the connectors which is a bit rubbish and needs a wiggle occasionally, and sides, tails and dash lights are in the fusebox, so yeah take it out (take lots of pictures and or drawings on which wires connect where and fuse ratings, then use some wet and dry on the contacts, but be careful, I have snapped a couple of lugs off mine once when cleaning as they were heavily corroded,
Thanks so much!, i'm wet and dry'ing them now.. so hopefully it should be fine
