Thick or Thin Flange?
7 replies to this topic
#1 welshy
welshy
  • 105 posts
Posted 19 January 2006 - 11:48 PM
I have searched all of the previous threads but can't find an exact answer.
What is the difference between the Metro anf Mini driving flanges that makes it necessary to use the metro ones when adding 4 pot calipers?
If its a case of the mini flange is too thick, can it not be machined down?
If its a case of the mini flange is too thin, can spacers be used?
cheers
Welshy
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 January 2006 - 08:24 AM
The flange controls the offset of the disk on the hub and no so much the wheel...
If you use a Mini flange with a metro disk the disk will not be in the middle of the caliper.
#3 welshy
welshy
  • 105 posts
Posted 20 January 2006 - 12:17 PM
If thats the case then surely it would be possible to insert a spacer between the caliper and the hub of a calculated thickness and then use a longer caliper bolt if necessary.
This would would offset the caliper correctly (see rubbish attachment) without the need of a metro flange and you could still use the vented metro discs.
There must be a good reason why this can't be done because surely it must have been though of before.
#4 marc426
marc426
    Just On Tickover
  • 6 posts
Posted 03 August 2007 - 08:52 AM
Hello guys,
Digging up this old thread,
Just one question : can't a normal mini flange be machined (rear face) to fit a vented disc under 4pots?
Is that the only difference between Metro/Mini flanges?
Thanks,
Marc
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 August 2007 - 06:19 PM
It's a lot of work to do rather than just fitting a cheap Metro part. Do you really think weakening the drive flange is a good idea? I don't. This has come up before, this isn't the first old thread asking this question.
The Metro part needs machining too though, the wheel mounting lugs need machining off.
#6 Fawlty56
Fawlty56
  • 23 posts
  • Local Club: Victoria Mini Club
Posted 04 August 2007 - 06:28 AM
Can any one tell me if this is a metro driveflange or a mini unit for 7.5 disc brakes
Attached File  Resize_of_IMGP0244.JPG   43.07K   2 downloads
The measurement across the flange is 1.8" (45.7mm)
#7 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 04 August 2007 - 10:03 AM
I did this, seems to be working ok.
#8 IwanDavies95
IwanDavies95
  • 78 posts
Posted 02 March 2014 - 08:41 PM
jordie, what size spacers did you have to use??
