Second facet pump dies after leaking oil for a while then leaking small amount of petrol during running.
Need to replace this as503 unit.
Isn't this comp spec pump a little overkill on the carbed r1 engine?
I thought the own yammy pump was lower pressure?
What pump are others using with this engine and do people use a pressure regulator with carbs?
Fuel Pump Again
YIANO
, Jul 04 2011 07:46 AM
2 replies to this topic
Posted 04 July 2011 - 07:46 AM
Posted 04 July 2011 - 09:01 AM
p would say you got to regulate fuel pressure why not use r1 oneSecond facet pump dies after leaking oil for a while then leaking small amount of petrol during running.
Posted 04 July 2011 - 02:58 PM
I have a very low mileage R1 pump assembly in excellent condition £50 plus delivery if required
David
David
