All prices plus p&p or collect from SK14
MPi engine and box, 56k miles, FSH, excellent runner £395
MPi black box relay £25
SPi engine and box, 62k miles, just had full service, new water pump etc, recon box £375
Speedo cables £5
Throttle cable MPi £8
Throttle cable SPi £5
SPi/MPi fuel lines set £35
Gearbox steady bracket £4
Gearbox steady bar/bushes £5
Engine steady bar/bushes/braket/bolts etc £10
Clutch housing breather flat type £10
Fuel inertia switches £5 each
Lambda sensor recently new £30
SPi full wiring loom (twin ECU plug) £75
Gear linkages, various types including reverse switch etc £25
SPi/MPi downpipes brand new £38
MPi bottom rad hose £20
Bottom engine mounting rad side £12
Set of yellow fog lamp relays £5
Radiator cowling £10
Coolant expansion bottle SPi £25
Charcoal cannister £8
Electric fan SPi £15
MPi injector unit £75
SPi injector unit £60
SPi/MPi manifold £12
Clutch slave cylinder £7
Clutch slave bracket £10
Starter motors pre engaged £15
Edited by R1minimagic, 15 July 2011 - 12:56 PM.
